EasySens® - inteligentní bezdrátový systém řízení s vlastním pohonem
Síťová bezdrátová automatizace budov? S vlastním pohonem a inteligentní? Pro novostavby i rekonstrukce? Bezdrátový RF systém EasySens umožňuje nejlepší možnou flexibilitu a je dokonalým základem pro realizaci individuálních požadavků do nejmenších detailů.
SELF-POWERED
Thanks to EasySens® wired power supplies and the change of batteries are things of the past: The Energy Harvesting technology enables a self-powered operation of products. Energy is extracted by using integrated solar cells and kinetic energy of the sensor environment.
INTELLIGENT
EasySens® transmitters and receivers are communicating autonomously within the building automation – without any help. Status synchronization and triggering of different control commands on basis of defined parameters. Bidirectional communication of energy self-sufficient devices with SmartACKnowledge.
Advantages of EasySens®
  • Cost effective with comfort by Energy Harvesting (energy production from the sensor environment)
  • High flexibility with sensor location, fast and easy installation
  • Reduction of fire load – no need for wires
  • Easy integration into existing buildings without the need for wires
  • Direct mounting at representative measuring points
  • Compatibility to other manufacturers by using the international standard (IEC 14543-3-10)
